Hi YannChris,
sorry for letting you wait - did not notice your post untill today.
Of cource you can't control the music/the files on a NAS with a Beo4.
Using the DLNA-port of the P! You need something else to control/to choose the music.
Might be a computer/WMP or som kind of DLNA-compatible software (there a lot of possibilities).
But using an iDevice or some Android-thing with a DLNA-app running on it makes life much more comfortable - especiialy if you listen to music in different rooms and don't want to create a looong playlist on your computer.
Take a look at the app PlugPlayer (actually I alread described that in my post in the danish forum).
There are versions for both iOS and Android.
With this app you can "see" your files on the NAS - or more correct: you can see what the server on the NAS has done with your files.
On a Synology there are differnt servers running, and you can install even more.
What the server does is indexing the files from the metadata/tags included in them, and displaying that to you in the app.
!!! Metadata/tags must be in the files to make this thing work - as an examble you won't see any coverpics unless the are there!!!
In the app/the interface you chooce where-to you want to play them. Means you chooce the PM!
With the Beo-remote you can only open the port on the Master/MasterLink, means pressing A-Mem/A-Aux, and of cource control the volume.
I have no experience with the Beo6 and the PM - but haven't heard that you can choose "where-to-play" with it.
Theoretically it might be possible because the Beo6 is controlling the server on the BM5 and the player there as well.
It might be a matter of sofware-updating to let it use another rendere.
Although I do not think that such an update will ever be made.
You can use other apps as well: google for "DLNA apps" - start with:
http://appadvice.com/appguides/show/dlna-streaming
Take a look at the '8player'..... You can AirPlay from that too.
Sorry for the long post, but these things are complicated - and there could be a lot more to tell.
Hi Oakley,
I have used the PM connected to my Audomaster with no problems ever since it came out - we got it first here i DK 😐
The disadventages you are describing I did not notice - meant nothing to me.
The PM is a damn good device, with excelent soundquality and it is easy to use (if you are familiar with DLNA and AirPlay).
It made my B&O-life much easier.
Greetings Millemissen
