Installing a System Module on a Beovision 8 - 32
Am I satisfied and proud owner of a BV8-32 and I have a System Module laying around, right now I dont need the extra SCARTs or Masterlink on it, but I might wanna install it later, according to dealer it was just a matter of plug & play :) but read a thread here about a similar install on BV7 (was tho DVB-S/T module) but you had to use Bang & Olufsen ServiceTool after install. In my instructions its saying just that I should use ServiceTool after installing...
Now first question, It is only plug&play for this card? I dont need to do a flashupdate or sw update?
My plan is via Beolink Converter 1611 hook the BV8 to a BS7000, (speakers connected to BS7000)....
Second question, I will be able to choose on BV8 if and when BS7000 should start up its speakers? I can start TV always with its own speaker and then when I choose via menu use speakers on BS7000?
Hope I make myself clear :)
MoglesMac
Sweden
Believe it or not (I didn't at first) it's actually as easy as it sounds. It slots in like an old Nintendo cartridge and just works.
You have to watch for the right software for the module in order to avoid some difficulties. Let your dealer do the installing/software update!
Ernie
And for the speaker question:
It all depends on  how you configure your setup ones connected in through ML/MCL.
In your suggested setup you set both your BM7000 and your BV8 to option 1 (default). Your TV will only respond to TV commands and your BM will respond to audio commands. To get TV sound from your BM you will select "AV" on your Beo4 followed by "TV". You BM will then present the sound from your TV. Should you desire to hear your CD through the TV you simply press "AV" followed by "CD".
/Lars
Ahh thanx all for the positive posts, and especially Lars for the info on beolink converter. Now im even more sure I have to install the module hehe good too have for future use.
Thanx all.
MoglesMac
Sweden
Only thing to add is that if you plan to use a Beolink 7000, make sure the software in the Beomaster 7000 is 1.3 as this will allow 2 way control of the Beomaster and one way of the Beovision.
Oh ok, think i read a old thred about that a time ago here. I do have a BL7000 but my plan right now is to have it in a floorstand in linkroom (thanx Peter for MCL2A-box) :). For fast control in mainroom i will use a Beo4 with a additional support from a BL5000. Would never use either BL5000 or BL7000 for TV-control, so far hehe
Cheers
MoglesMac
Sorry for bumping this but does this also mean that if my BM7000 is under v 1.3 I will also loose 2-way-communication to link-room via MCL? or
"just" in mainroom?
Just want to be sure before i take the plunge hehe
Thanx in advance
Jesper
Sweden
