Hi
Is it easy to plug a dolby surround module into a beovision avant 28 ?
Thanks for your help
BR
Olivier
Hi
BR
Olivier
i have avant rf 32 dvd decorder . is it possible to fit in avant 28 vhs?
if yes then plz tell me how to connect it.
thank you
thank you
thank you
Dear iiirshad,
Plug your brain into your head !
Why post a question above mine ?, create your own post.
Thanks !
"Plz" ask moderator to remove!
Hi Leslie,
U R a fast learner...
