Ideas for non B&O 4ohm speakers (minimum 150 watts) suitable for a BeoMaster 8000
Hi
Can anybody recommend a non B&O 4ohm speaker that goes well with a BeoMaster 8000 suitable for a wide range of music types (classical to rock)?
Kindest regards
Richard
How much are you looking to spend? B&W's XT4 has a nominal impedance of 8Ω, but dips as low as 3.1Ω which would provide a good challenge for an 8000 to drive. They're damn difficult to drive and hence have got a reputation of sounding poor at high volumes, but as long as your amplifier can handle any kind of load (which the 8000 can), then they stay in control beautifully even up to high volumes.
Although they do cost £1700.
You can consider options from Elac. Their speakers are mainly 4 ohms. www.elac.com
I have KEF iQ9 speakers since about 2 months and they sound very good. The design is not amazing, but for 1500€ they're great.
I use them with an old Braun atelier R4 amp.
I use 4 pcs JAMO POWER 555 with my BM8000. Contemporary and powerful. I couldn't wish for more.
My Beomaster 8000 is driving Beovox M150's. They handle it well and sounds very good. I'm not tired of listning to them. That's for sure.
