I think the BV 7-40 is a little bit dark!
Does anyone have some info how i can increase the lightning on the BV 7-40:s service menu? I have tuned up the brightness and contrast, but i feel its to dark anyways...!
Regards
Do you miss some details in black parts?
If that is the case, that cannot be solved beause that is limited to the contrast ratio of the used panel.
I think BeoLab means it's too dark... 😕
It's entirely possible there's something wrong with the set. I've seen a BeoVision 7-32 which is intermittently dark, possible yours is suffering from the same issue except it's constant?
Either that, or you haven't yet got used to 'that B&O picture', which is sometimes darker than other sets, but usually more natural...
I also find the picture dark especially when I first turn the set on, seems it needs sometime to adapt to the room.
The sets at the dealers have brightness/contrast and colour at mid settings, which on mine is too dark and too much colour, I set brightness/contrast +3-4 levels and colour down 3-4 and it helps, though looking at the picture from the side it is bright compared to head-on.
The dealer brought another set and picture seemed fine on Narnia dvd (battle scene), then returned to my set and picture was the same - so we live with it and I find I often adjust picture during the evening or dependant on program. We have NTL oops I mean Virgin cable and usually use analog 1-5, as digital channels often need format 3 to see complete text on commercials etc.
As Alex says - perhaps I need to get use to B&O picture. - or is plasma better ?
Plasma is definitely better, but it's not as 'smart' as LCD, it's MUCH more fragile.
LCD panels take time to warm up, as you say. It's only a few minutes, and the same thing can be seen on all LCDs.
The sad thing is that you pay $10000 for a TV set that has worse pic quality than sets that cost $2000...
I had mine for a week, and sold it as fast as possible.
After you power on it  takes 15 min. before the back lights is on 90% light, don't know have long it's takes before it's at 100%.
but for the first 15 min it will be very dark in daylight, and if the room light doesn't hit the TV light sensor.
Beolab:
If you think your BV7-40 is dark, you should see my old MK-1 BV7-32! Some DVDs, for example, are so bad that they are almost unviewable (The Da Vinci Code is a good example).
It's definitely the panel. My dealer kindly lent me a MK-III BV7-32 when my TV was in for long-term repair, over Xmas. It was much brighter, better contrast and the screen was less 'gloomy' in appearance. As soon as I received my old MK-1 BV7-32 back from repair, I noticed a huge difference.
Apparently the new BV7-40, launched in the US this month, is significantly better and nearly on a par with the BV9. If that's the case, I'm certainly upgrading my old BV7-32 when the new BV7 is launched here in the UK, later this year.
To answer your question - there's little you can do to change your current TV. It's the LCD panel, sadly. I'm assuming you have one of the first revision BV7-40's?
HEHE i purchased my BV 7-40 MK II Last week and it is the latest firmware: TYPE No: 9361 = AP SW 7.5
Does anyone have the pin-code to the real service menu for the BV 7-40?????????????????????????????????????????????????????
Ha! After 3 hours watching my BV 7-40( MK II) are much brighter in every part in the picture! I noticed it when i looked at a Lost episode (DVD) and the scene where dark and had poor colors and like a bright  filter layed on top of that.  But now when i rewind after 3 hours the picture is much more magnificent and brighter over all ! Not far away from perfect "HDlike" picture with DVD i think..=)
(Note: The TV have just been turned on for about 5 hours total)
