I need something dummed down for me....... Apple TV and Beo4 (new user)
Here is a link to a thread that explains a little more about how I got the Apple TV to learn the Beo 4 commands.
Apple TV Remote Control -
The Beo 4 itself uses a IR frequency that the ATV doe snot support.
2 options should:
- There is a STB controller available that simulates the Apple Remote. You would need to connect an IR Blaster cable from the TV to the ATV. This is how that is running with my BV832 US version that I have for a year or so.
- The other option that I suspect works as was stated above should work too as the IR Blaster supports a frequency that the ATV supports. Again you need to connect an IR Blaster Cable from the TV to the ATV.
The TV should have had one included.
Personally even though I have option 1 running I will try the 2nd at some point as some things will not work with the B&O ATV implementation. I.e. holding the "Go" key down.
Cheers
JK
I guess I will buy one of those cables and get the software updated since the cable did not come with the TV.
Also.. was one of those cable socks supposed to come with the TV or is that also an optional purchase ??
Hi Luke,
The ir cable should come with the TV, the dealer should throw in a piece of cable sock for you.
It will take the dealer very little effort to put in the puc code for the Bvis 8 to operate the apple please get them to do it as it works brilliantly!!
Good luck
Hey thank you for all of this. I will email them and ask them if it is possible... because we intend to use Apple TV more than the DVD player and this seems like a really good feature. I'll also ask for some cable sock.
Its a easy fixed problem.
Just delete the remote in the Apple TV and it will work just fine!!🙂
www.installsolutions.nl
10 Juli 2009 Online B&O products
I have tried that.... it just doesn't work :-(
So do you mean you have it working??
