Humming BL8000’s connected to iMac
Another option is to use an external USB sound card (like this one:
Hi SteveThanks again for your valuable feedback! In the meantime I changed my setup, and connected the BL’s to a Chromecast Audio which I still had lying around. Play to the CC via Roon. Works great and no more hum. Happy me!🙂Hi, Another option is to use an external USB sound card (like this one: https://soundsheavenly.com/music-input/17-beomaster-5-beosound-5-aux-usb-input-converter-also-works-as-pcmac-sound-card.html ) to connect the speakers, instead of the headphone socket on the Mac, this will avoid the noise when the Mac goes to sleep. Kind regards, Steve. Steve. www.soundsheavenly.com Sounds Heavenly are proud to sponsor BeoWorld!
also does the trick. I have a bunch of these as a "swiss army knife" solution for lots of problems like this. I originally bought one to use on airplanes with a VERY sensitive pair of in-ear earbuds that I owned about 20 years ago. I then got a second to put between my AirPort Express and a pair of BeoLab 3's back when the AirPort first hit the market...
Cheers
-g
If you have questions about or problems with B&O equipment, these should be directed through your dealer and/or B&O's Customer Service department.
I cannot be a "short circuit", bypassing these communication channels.
-geoff
Thank you Geoff! Always nice to see you chime-in! Much appreciated!https://www.amazon.com/Koss-155954-VC20-Volume-Control/dp/B00001P4XH/ref=sr_1_2?keywords=koss+headphones+volume+control&qid=1584354590&sr=8-2 also does the trick. I have a bunch of these as a "swiss army knife" solution for lots of problems like this. I originally bought one to use on airplanes with a VERY sensitive pair of in-ear earbuds that I owned about 20 years ago. I then got a second to put between my AirPort Express and a pair of BeoLab 3's back when the AirPort first hit the market... Cheers -g
