Humax Freesat STB/c
I have a Beosystem 2 with the latest STB controller software fitted v4.01 West Europe.
On the list of devices it can control are the following Humax devices:-
Humax DTT-4100      Humax PVR 9200T      Humax CI 5100C     Humax PR HD1000     Humax HDCI 2000     HumaxCI 8100 PVR               Humax F1-VACI
My question is the current range of Humax satellite boxes are FoxSat      FoxSat HDR       iCord      Combo 9000
Will the commands from any of the installed devices control the new boxes ?
Has anyone out there got one working ?
Is anyone out there using a Humax satellite box ?
preferably a HD one any info before I go off and make a purchase that wont work.
OR is anyone receiving HD freesat ? what box are you using.
Hi bdm01
I use Humax Freesat and control it with Beo5 however I have to get my dealer back to tweak some of the functions.
I don't have a Humax STB of any kind, but I have done some research into the subject and the following are my conclusions:-
The Humax HD Freesat box is supported by the PUC and can be uploaded by the dealer.
All the Humax remote infra-red signals I reviewed used NEC protocol with a carrier frequency of 38Khz
The following is the protocol used by all the Humax codes I reviewed
In particular, I compared common commands used by the Humax PR HD 1000 and the Freesat HD and I found them to be the same.
As an example I looked at the UP & DOWN commands and both had the following bit string:-
UP       binary BITS=11111111 01101101 01110111 10001000
DOWN binary BITS=11111111 01101101 01010111 10101000
As you can see above all Humax STB's uses the same product address of FFB6
So, the conclusion is that for common commands, it will work, but you will find that there are a couple of FREESAT commands which will not be available.
Thanks Keith,
Thats what I call research ! I'm using a beosystem 2 so it's not PUC but STBC and I have the latest S/W
It might be easier to go for the HDCI 2000 that is on the list, but I sort of hoped that I could use most of the functions of the Foxsat box. maybe I still can but as you have explained we can't be sure.
Thanks for your input
I did some further research and looked at the available commands for the boxes you mentioned and I have listed them below.
HDCI 2000 FREESAT HD FOX
1=0
2=1
3=2
4=3
5=4
6=5
7=6
8=7
9=8
10=9
11=Power
12=Up
13=Down
14=Left
15=Right
16=OK
17=TVradio
18=Source
19=EPG
20=OPT
21=Back
22=Last
23=Red
24=Green
25=Yellow
26=Blue
27=PPlus
28=PMinus
29=VMinus
30=VPlus
31=Menu
32=I
33=Mute
34=List
35=Text
36=Wide
37=VFormat
38=PageUp
39=PageDown
1=0
2=1
3=2
4=3
5=4
6=5
7=6
8=7
9=8
10=9
11=Power
12=Up
13=Down
14=Left
15=Right
16=Select
17=TvRadio
18=Source
19=List
20=Guide
21=Exit
22=Back
23=Red
24=Green
25=Yellow
26=Blue
27=PMinus
28=PPlus
29=Menu
30=Info
31=Text
32=Sub
33=Audio
34=Wide
35=VFormat
36=Opt
1=0
2=1
3=2
4=3
5=4
6=5
7=6
8=7
9=8
10=9
11=Power
12=Up
13=Down
14=Left
15=Right
16=Select
17=TvRadio
18=Source
19=List
20=Guide
21=Back
22=Exit
23=Red
24=Green
25=Yellow
26=Blue
27=ChUp
28=ChDown
29=VDown
30=VUp
31=Menu
32=Info
33=Mute
34=Text
35=Text2
36=Text3Wide
37=Text4
38=Text5
39=G
