How to watch PC in Link rooms
Hello,
I have my PC connected to my BV8-40 in the living room and would like to watch this in the Link room (Beocenter 6-23). I can watch all other outputs ie SAT, DVD, Cd from the link room but dont know which button to use on my Beo4 to view the PC i n whilst conected to the BV8-40 in the main room.
I have used Link¬PC, L-PC but to no avail!
Any help/inofrmation would be highly appreciated.
Regards
Jola
Hi Jola!
At first: How did you connect your PC to BV8-40? If only HDMI, you cannot watch this in your link room! You have to connect the PC also to an analogue input (p.e. VGA).
Regards
Räuber
Hi Rauber,
Thanks for your response!
Yes i connected the PC to the BV8-40 using a VGA cable.
REgards,
Jola
Hi Jola,
I think it should work if you use a VGA cable. I would also connect an audio cable from PC to BV8-40 to check if you can hear audio files from your PC in your link room.
I think you configured the AV3-socket (VGA) on your BV8-40 as "PC" so you can watch your PC on the BV8-40 by pressing PC. If none of your inputs of your BC 6-23 is configured as "PC" you have only press PC on Beo4 in your link room.
Hope it works!
Regards
Räuber
Hi Rauber,
That is exactly what i have done- configured the AV3-socket (VGA) on my BV8-40 as "PC" and can watch PC on the BV8-40 by pressing PC. I also have an audio cable connected and everything works fine on the BV8-40.
The issue is when i presss "PC"on my Beo4 in my link room when the PC is connected in the main room, nothing happens and i dont have any Pcs connected to the linkrooms - I have a Beocenter6-23 and Beovision6-22 in different rooms and nothing happens on both!
REgards
Tony
Hello Tony,
in the user guide of the BC 6-23 it is described that the PC-button activates a PC which is connected to the DVI-socket of BC 6-23. Probably therefore "PC" and also "Link PC" does not activate a PC in the main room.
I would now try to change the AV3-socket of your BV 8-40 from "PC" to p.e. V.AUX. Then you should see the PC-monitor on your BV 8-40 by pressing V.AUX in main room and (hopefully) V.AUX or LINK V.AUX in link room.
Sorry, I can´t test it by myself because I have no BC 6-23.
Regards
Räuber
L-PC will activate BV8`s PC input on your BC6, but your PC must be connected via video (composite) and audio (L-R) to your videomaster.
Check it by connecting any video source to the AV3 video input and press L-PC in your BC6 linkroom.
Stefan
Thanks Stefan and Rauber,
I am away from home till the weekend and will surely give this a go and report back if it works!
Regards
Jola
