After I got a Beovision 3-28 for close to nothing... (everybody seems to want to get rid of the bulky TVs and buy the flat screens) I wanted to set up the STB-C to work with my DBox 2.
But in the List (STB Table 5.27a according to the service menu) there are only 2 entries!
Does that mean, the dealer that set up the tv deleted all the other entries???
If so, how can I update the list myself? I know it is a software update.
What cable is needed? I suppose I will not need to open the TV, should work via the IR connection...
And then use a Flash Tool (where to download?) and cables: 3375397 (cablekit)?
I updated the firmware of lots of Set-Top-Boxes, Routers etc. using ethernet and/or RS232 cables...
Any help is very much appriciated - PMs are welcome, too 😕
Ralf
Home Cinema: Beosystem 4, Beolab 7-4 (Center), Beolab 9 (Fronts), Beolab 4000 (Rears). Projector: Sony VPL-HW55
Home Office: BeoVision 11-46, 4 x Beolab 3, BeoCenter 9300 (BLC 1611/ML/NL)
Dart Room: BeoPlay V1-40 on floor stand
Guest Room: BeoVision 7-40 MK IV, Beolab 7-2, BeoSound Ouverture
