How do I turn off the harddisc at bv11, when I don't use it? (the most of the time I don't use it) I have tried to turn timeshift off, but that do not help.
How to turn off the harddisc at beovision11?
What is the reason for turning the HDD off?I rarely use it either, but have no problems just leaving it.How do I turn off the harddisc at bv11, when I don't use it? (the most of the time I don't use it) I have tried to turn timeshift off, but that do not help.
I guess it’s because the hard disc is making some noise? I’ve noticed, since I moved my Avant 55 with a hard disc to a new location in the house, the hard disc is working and making noise even if I don’t use it at all. It’s placed in a cupboard which unfortunately works as a resonant box.What is the reason for turning the HDD off?I rarely use it either, but have no problems just leaving it.
Could be a reason, but the HDD in my BV11 is dead silent.Let’s see what the OP responds 🙂I guess it’s because the hard disc is making some noise? I’ve noticed, since I moved my Avant 55 with a hard disc to a new location in the house, the hard disc is working and making noise even if I don’t use it at all. It’s placed in a cupboard which unfortunately works as a resonant box.
If you are a gold member you can access the newly published repair guide for BV11.There you maybe can see how to detach the HDD.yes it is because it is making noise. Not on my mk4 but on my mk1. So what to do?
I am not a gold member. Maybe someone knows a good trick to turn off the HDD? I cannot be the only one that the HDD noise is a problem… ;-)
Am I the only one on this forum who thinks my HDD at my BV11 mk1 makes noise?
