A suggestion:
1. Examine the Masterlink cables first, especially the connector ends. You will either have a B&O store purchased cable ( fully intact, with set lengths ), or a ML custom length cable put together by someone. I have made and pulled custom cables for three properties ( 13 rooms ), and I used a fly fishing set with a magnifying glass to complete them correctly.
As I recall there are 21 different wires inside each ML cable: If a few are cut, or broken, there will be scratchy or no sound at all. If on the other hand, your sound is good, then you are done.
2. If you are going to possibly add more speakers along the way, look into buying an M-L junction box. We kept adding more Beolab 2000 speakers here and there, and the junction box is well worth the nominal cost.
