Hi all,
I'm in the process of buying a second hand beovision 7. I was looking at a new beovision 11-55 and read all reviews I could find. I do like the design of the 11, but my living room is better suited for a less tall tv.
Some reviews also said the beovision 7 is 'better', picture quality wise, but definitely sound quality wise, which is why I started looking around at second hand beovision 7s. I don't care much about smart tv stuff, as I plan to connect an xbmc device, which will be used 95% of the time.
I found this particular set online, but I've found conflicting advertising. Can anyone see from the pictures whether it is a 40" or 55" variant?
Thanks!
