How to start with automation and B&O?
Hi all,
I'm a B&O newcomer, with practically zero experience of B&O and automation.
I've got an Avant 55" and BeoLab 18's being installed on the 30th of Jan and I'm keen to start with some automation as soon as possible.  The thing is, there's very little information out their on how to get started and what products are best, particularly for B&O integration, the info which is available is sometimes confusing.
What experience or advice have you got for me on this?
Initially I just want to start with lights and some basic security (sensors / camera).  I've ordered some Phillips Hue lights for some effects but lights around the home would be desired.
I'm not fussed about automation systems driving my A/V, as that's what I brought the Avant for, so I really just want simple automation.
What sort of pricing should I expect for this and any B&O additional products (NLGW?)?
Any advice or links to other info sources are welcome?
Cheers,
Dave
Hi David try the beo integration website in another thread some inspirational ideas as I looked through
The BeoLinkGateWay is what you need!
You can find the BLGW Installation Guide ver. 1.0 there.
I have just sent an Email to Lee, to suggest the creation of a new section  for Home Automation and B&O Integration...
The BLGW is a much better automation tool than the mlgw.
Pick one up. The programming is easy.
Quick question re BLGW as you've spent some time with it - had a look at the manual and the connections look identical to the NL/ML converter. If i pick up one will it replace the ML/NL Converter (ie make it obsolete)?
Clearly it adds all the automation features but it seems to me as if also does all the things the ML/NL converter does?
No, it does not act as a converter unfortunately.
Phil said it correctly.
You'll need both.
The blgw is only an automation engine.
The NL/ml converter is nice too as it can be an active kit as well as converter.
Also, on the blGW you'll find that the home control on te avant menu for lighting control is pretty amazing.
You can control your entire automation system from any b&O television.
And with a beoremote one you may program lights in, etc.
I think you'll be pleasantly surprised about the blgw functionality.
Hi there
i agree we will need a automation area as this area is going to have more and more questions.
i have some questions that I hope someone knows the answers too.
1) when I buy a BLGW it will see my existing ML products, will I be able to get the onscreen control on my BV7 ?
2) are the connected IP camera available to view on the BV7?
3) can I add a button to the app that sends a http string to open the front door relay?
4) how much is the beolink gateway in the uk?
5) can I configure the BLGW to connect to a lintronic device to allow it to send custom strings to triggar the lintronic to fire out IR commands?
6) can I configure custom strings to talk to my ilight controller over rs232?
7) are older products like a bv6 able to be placed into Zones?
8) the BLGW works with Phillips hue, this is great news as then room lighting is as simple as adding new bulbs and connecting to them. Do hue have special light switches?
9) the beovision 3 & 6 are not on the list. Does this mean the BLGW will be able to see them and control but not pass commands back and forth or will it not see them at all?
sorry for all the questions but the BLGW for me is the biggest improvement into automation for many years and I cannot wait to get one.
i tried for ages to get control 4 to do what needed but ultimately what I wanted was B&o to be the main system and now it looks possible and I can even bridge my new and old products together which means I can move forward again.
cheers all
I'll answer within
Seanie_230 wrote:
Hi there
Nope. This is network link only
Nope. NL only
I'm not sure but under the custom strings if you know the protocol and can write the code it will send it.
Can't help on this one.
I would think so as long as the lintronic will receive and send commands over ip
I think so
I do not think you'll be able to do much with the older products.
I'm no help on this one. Don't know about hue
I think the blgw will not control these
cheers all
Beovision 7 MKIV (Blu Ray) Beolab 9 Beolab 6000 Beo 4 Beocenter 9300 Apple TV SKY HD Optoma HD65 Projector Lintronic TT455-RT-238 Beovision 3 MKII
