Hi everyone,
I've received a few questions about this, so I thought I would post a "how-to" guide. Basically, when you connect PlayMaker to a Beosound or other audio system (instead of plugging speakers directly into the PlayMaker), the best option is to fix the PlayMaker volume at full (line level) output, to get the clearest sound. Here is how to do it using a Beo4 remote:-
1) Press A.AUX or A.MEM to set the Beo4 to Audio mode
2) Press LIST until the Beo4 display shows A.SETUP then press GO
3) Press LIST until the Beo4 display shows S.STORE, press 0 (zero) then press GO
The PlayMaker light will then flash green to confirm that the volume has been set. Connecting the PlayMaker to a Beosound audio system is very straightforward. First, you need an adapter to convert the PlayMaker for use with normal audio cables (link)
This adapter connects a cable like the one below and this links to the AUX socket on the back of the Beosound audio system ()
To listen to the PlayMaker, simply press A.AUX on the Beosound keypad, or select this on the Beo4 remote control by pressing the A.AUX or A.MEM.
Hope this helps!
Kind regards, Steve.
