Hi everyone,
I own a couple of S3 speakers for about 11 months right now and I absolutely love them both. However, I have recently made the mistake of upgrading their firmware software to the latest version using the windows utility available on the B&O website. FYI, I upgraded the firmware on both units. Unfortunately, I have had nothing but problems ever since. I have listed the many problems I have been experiencing since below.
Problems:
01 - Daisy-Chain Sequence: The hardware key sequence for putting the two speakers in daisy-chain mode (holding down the B&O button until the lights turns into blinking Amber) will only function 2 times out of 6 attempts. you can hear the speaker been three times which should mean you are in the daisy-chain mode but the blinking light will only blink white as opposed to amber. This was not the case before the firmware upgrade.
02 - Daisy-Chain Pairing Light Sequence: Once you finally get both speakers into the pairing mode (blinking amber light) pressing the B&O hardware button on the master speaker (Speaker 01) will stop the blinking amber light on the master speaker but the one on the slave speaker turns white, before double beeping and the speakers get to be online. Originally, the blinking amber light on both speakers turned into solid Amber light for a while before beeping twice signaling the successful daisy-chaining
03 - Slave Speaker Volume Drop After Pause: The most annoying of all the problems which have been showing themselves after the new firmware by far is a massive volume drop on the slave speaker after a short silent pause (5 to 10 seconds). The volume is alright for as long as there is a constant source of audio from the computer but as soon as you want to skip the track in the time it takes the next one to play the massive and supper annoying volume drop happens on the second, slave speaker. This was also not the case prior to the firmware upgrade.
So, what I would like to know is that if anyone else has been experiencing similar problems or not. Also more importantly, is there a way to revert back to the original firmware these two magnificent speakers came with!?
P.S.
This is how I have set them up:
Physical Setup:
Speaker 01:
Connected to my Windows 7 Desktop via a gold-plated USB Micro-B cable.
Connected to Speaker 02 via a gold plated 3.5 mm to 3.5 mm cable - From Line-Out Mini-jack port
Speaker 02:
Connected to Speaker 01 via a gold plated 3.5 mm to 3.5 mm cable - From Line-in Mini-jack port
Speaker Configuration:
I have set up my two speakers in the Daisy-chain mode where my speaker 01 with the USB connection is the master, left channel and the Speaker 02 is the slave, right channel.
