How to reset the ip of the BEOLINK CONVERTER NL/ML
Hi all,
I had the Beolink convertor working but had the ip address set to static. However after renewing my provider modem (with a different ip range) I am not able to find the web page of the Beolink anymore.
How can I reset the convertor to the standard ip address?
All tips are welcome.
With kind regards.
Ivan
Hi Ivan,
Press and hold button and watch the light (has to flash 7 times), then release the button and right after press just once.
Pat
Thanks for this scheme however where can I find the setup button? I did look multiple times at the beolink convertor however  couldn't  find any button or lookalike.
I did manage to resolve the issue by directly connecting the beolink convertor to the pc. After adjusting the ip from the pc in the static range of the beolink convertor I could succesfully ping. Then I was able to connect again to the web interface.
Regards.
on the bottom of the small hole just aside the light; use for example a paperclip to press it
