hi,
 just bought a beovision 7 32, collecting it tomrrow sometime.
 i beleive there are some allen  bolts you have to remove to lift off the monitor from the stand, does anyone know what size allen key you need? like a 4mm or 3mm maybe? what do you have to do exactly to left off the screen from the stand? do you have to tilt and lift off? not sure really, canr find any info on the net about it.
thanks phil
