How to remove a Beosound 1 grill?
Can anyone give me a bit of guidance please!?
Cheers
 Nigel
There is a good video on YouTube entitled.......beosound 1 demo and grill removal
about 3 minutes long, worth a watch if only for the warning on it about scratches
Cheers
Nigel
The easiest way to remove the grill is to lay the unit flat on its back and with the CD mech end facing towards you place it against your knees and slide the grill up from the bottom. To re-fit, simply spin it around and do the opposite. It's a two second job, not worthy of a 3 minute video on You Tube 🙂
Thanks guys... It's off! (And about to be repainted.....)
Cheers
Nigel
Cheers
Nigel
Cheers
Nigel
How do you succed in repainting the grill..?
Wow! That seems like a long time ago!
I got a car bodyshop to re-paint it. It came up great in a Skoda metallic blue.
And thank you for reminding me to ask for it back from someone I lent it to months ago!
Cheers
Nigel
Did you remove the black cloth on the back of the speaker grill before repainting it ?
If so, how do you remove it ?
