Hello all Beoers
I am going to relocate my BV7-32 and BV-10 and speakers to a new appartment. I intend to use the old cables but the plugs have to be removed before I could pull the cables out.
I think I can open up the plugs for the speaker and re-solder them but the master link plug seems a bit tricky. I am wondering if it is possible to buy the new master link plugs and reconnect myself. Does it require a special clam to close the plug and where can I find the pin assignment for the master link and power link?
Thank you all in advance. Any suggestions on how to move them around is also welcome.
Bouncer
