How to program the radio on a Beosound Ouverture
I read some place that the radio on an Ouverture is really advanced, and was therefore hopeing that i could program it to always start up on the same channel when i chose radio.
1. How can I tune to FM 99.0 and store this under nr. 1 on thr radio
2. How can I make the radio start up on this channel when I press radio on the Beo4
Lars
Hi Lars.
The radio will always start on the last channel you used.
Are you using a Beo4 or a Beolink 1000 to tune it?
With a 1000, I think it is like this
Radio
Goto
990
Store
1
Store
With a Beo4, it is a little more complicated, but still do-able.
Andy T.
Why not upgrade your membership of this site to silver (£15) or gold (£30) and you can download the user manual and gain full use from your Beosound Ouverture.
It worked!!!!
Thank you!
