Hey friends!
So I came across a BL7000 and am now using it with a white 6500 beosystem, to which I have connected a white 4002 turntable (which goes through a riaa preamp I built). The problem is since the BL7000 doesn't see the old turntable as being a datalink connection it won't show "phono" as a possible source. I have to instead use my BL1000 remote to select phono. Same goes for when I plug something like an iPhone. Is there any way I can select inputs on the BL7000 to sources it doesn't think have anything plugged in?
Thanks as always,
Austin
