I'm new to this forum and am online as my local B&O center has closed in Edinburgh.
I have a Avant 32" TV with DVD. It generates a great picture from analogue. However I want to get the TV set up to receive a digital signal.
Question One: what kit / digi-box would you recommend?
Question Two: How do you set it up via the scart? E.g. do you just plug it in or is there settings on the TV that need to change?
Question Three: Can you sync to control the digi-box with the Tv remote?
Any help would be much appreciated.
Many thanks
Ben
