www.bang-olufsen.com/.../EN_WPL_TX_manual_setup...
How to debug Beolab Transmitter1 / Beolab 17
Hi
Let's try this again,this time with the correct link ( hopefullyhttp://www.bang-
www.bang-olufsen.com/UserFiles/File/RightNow/EN_WPL_TX_manual_setup_guide_FAQ.pdf
Just curious - did you ever get the issue with the Transmitter 1 / BL 17 sorted?
Not yet! I'm still waiting for the 2nd pair of beolab 17. Apparently it takes longer than expected as the dealer is waiting for the wall brackets from B&O.
I've got the 2nd pair of Beolab 17 and I experience the same issue so it must be Beolab Transmitter 1 faulty. I will run few more tests before to send it into service. Beolab Transmitter 1 is placed just above the a/v receiver(the cables are short) so I'm wondering if that could be an issue too.
I will update this post once I get the Beolab T1 from service. I wish there could be a way to debug the issue (i.e. if there is a lack of channels, signal issues etc) instead to make blindly assumptions.
Did you see the link I posted the other day which does a good job walking you through the process of setting up the T1.
I had similar issues as you describe until I was lucky enough to get someone from B&O to "hold my hand" and walk me through the process, step by step.
That solved the problem, good luck and please keep us in the loop as you tackle this issue.
The T1 seems to be quite 'sensible' to heat.
Placing it 'just above the a/v receiver' might not be a good idea.
