How to deactivate front speakers?
No thats the only way to do it.
Would it not be possible to plug the Pentas in as rears, then when yo want to listen to a CD, press 'speaker 4'?
When watching TV, the Avant would be on 'Speaker 1' as it wouldn't detect front speakers.
Just a suggestion, might be wrong.
Andy T.
Andy,
very smart idea!
I am curious if this works.
Ralf
Home Cinema: Beosystem 4, Beolab 7-4 (Center), Beolab 9 (Fronts), Beolab 4000 (Rears). Projector: Sony VPL-HW55
Home Office: BeoVision 11-46, 4 x Beolab 3, BeoCenter 9300 (BLC 1611/ML/NL)
Dart Room: BeoPlay V1-40 on floor stand
Guest Room: BeoVision 7-40 MK IV, Beolab 7-2, BeoSound Ouverture
I think that you will find it is not possible to configure rear speakers without front speakers in the set up menu of the Avant. It has to have speakers set as front to allow you to set rear speakers. You can "fool" the Avant by plugging the PL cables into the front sockets, configuring them on screen, then unplugging them and plugging them into the rear sockets and then you can access the set up menu for rear speakers.
HOWEVER, why not just buy a pair of Lab5's and be done with it? 😁
Opman
MENU > SETUP > SOUND > SPEAKER TYPE > FRONT "NONE"
Its the only way the TV will play speaker 1 as default. Then just select:-
MENU > SETUP > SOUND > SPEAKER TYPE > FRONT "BEOLAB PENTA" when listening music.
