How to connect Beolab 7.1 to non b&o TV
hi
Im would like to try and use my old Beolab 7.1 with my Panasonic TV, I'm guessing I'm going to have to come out of the headphone socket but how do I get the speaker to switch on?.
regards
chris
You'll find the right cable here:
http://www.soundsheavenly.com/
Update, sorted it myself.
got a 3.5mm jack connected to a mk3 powerlink then took a old usb cable plugged into TV and used the 5v off that.
so now I have switching on off of speaker when the TV turns on and off.
Cheap as chips!!
Good solution, well done!
