How to connect Airport Express to a Beocenter 6-23?
Yesterday I connected an Airport Express to the Beocenter 6-23 in our kitchen. I connected it to the AV3 phono connections on the side. All works with one flaw - it seems that it only reacts to the Camcorder input on the Beo4 (which is a LIST button).
Is there anyway to connect the Airport and have it triggered by one of the hard buttons on the Beo4?
E.g.
Scart to 3.5mm adapter (and assigning to e.g. DVD)?
(do not have a cable like this but saw it on eBay)
Using the audio inputs next to the Component inputs?
Best regards,
Riven
Bought a SCART to RCA adapter on eBay and then connected the Airport using an RCA to 3.5mm cable. Set the input for AV2 as DVD and now I can stream music to the Beocenter 6-23 which is also distributing it to a Beolab 3500 in our bedroom (using the Beo4 DVD button).
Works like a charm.
