How to connect 2 BL 8000s, 2 BL 6000s , 1 BL 4000 and a BL 11 at the same time ?
Good morning Beoworld !
After years of patience and searching i was able to assembly an ALL RED B&O speakers setup:
2 Beolab 8000s , 2 Beolab 6000s, 1 Beolab 4000 all in Red Colour  and i plan to buy a BL 11 or a BL 2 in the near future.
Now i wanna ask: in which way would i be able to connect all the 5 Speakers at the same time ?
At the moment i have an  Ouverture , but evene using splitters (i'm not a fan of splitters anyway) i would be able to connect 4 speakers …..
Should i use a Beosystem 2 or 3 ? Does it neeed a TV or can i use the Beosystem even without sa TV?
Many thanks in advace for your suggestions !
Thank you for your kind and very detailed answer !
Actually i own a MK3 Beovision 7-32  but it 's located in another room and that thing is HUGE so moving it is not an option !
I would like to use all 5 speakers and the subwoofer at the same time, so in the end i'll probably  buy a Beosystem 2 or 3 , and a BV 6-22 or Beocenter 6-23 as a monitor !
Maybe use an Xtra Active speaker kit? You could even rig it so that you can control the volume of the different sets independently?
