Guys
My BC1 is starting to stop midway through DVD playback.....
Any ideas what could be causing this, or what I can do to clean the lens....
It doesn't like my CD lens cleaner disc that I have...
Gary
Guys
Gary
It might be an overheating issue, which was addressed in
help?
help?
Seem to recall a similar BC1 issue where it was suggested that there might be a timer issue if CDs were found to play right through, but longer running DVD's turned off prematurely at about the same running time. ( But I don't know whether that turned out to be the actual problem in that particular case.)
Graham
so, is there a cure!?
my DVD1 had problems where the DVDs kept skipping and freezing.
i opened the case.
the lens was foggy with dust!
got a cotton bud for cleanign your ears (clean one) and used some isopropyl alcohol that you can buy from chemist or a hifi shop. alterntaively the sterile wipes do the same trick.
try that.
my DVD1 works beautifully.
i opened the case.
got a cotton bud for cleaning your ears (clean one) and used some isopropyl alcohol that you can buy from chemist or a hifi shop. alterntaively the sterile wipes do the same trick.
try that.
Not sure I want to open up the BC1? Anyone in or around London that can help me?
Gary
