My BV8-40 was supplied with the bare minimum of controllers. It has about 4 controllers in total - Apple-TV and Sky which I requested and a couple of others.
I want to add more, eg Freeview HD, DVD, DVR etc.
How do I do it?
AP
How do I do it?
AP
You mean I have to get a dealer out to my house?????
I have to be in during the daytime and pay an extortionate call out fee?
What codes should I get for free on installation?
I'm genuinely shocked.
Is there a controller for BT Vision?
Thanks in advance.
I see nothing strange in this procedure. You pay only for the dealers time, and not for the PUC update as such.
It has to be done by a B&O dealer or certified service technician with the right software. It´s a fairly quick procedure, and your television should receive the latest firmware at the same time.
You can have all the codes you desire, but I understand the memory space is limited, so you cannot have 100% of the available PUC.
The latest list of PUC available at the Forum can be found here:
http://forum.beoworld.org/groups/available_3rd_party_products_in_the_puc_library/default.aspx
Thanks in advance.
Yes. Have a link to the list in my post above.
Whatever you need or want, provided it's available.
