I think that's a yes!
Horizon update?
In that case I suppose, that it will be a bit different ;-)
I hope it's sufficiently different from a "interchangeable panel Eclipse". Or maybe it's the same and he's getting confused.
And why is in the Horizon thread?
I asked a dealer about an updated Horizon wich I would have loved. He told me that no such thing is coming in the near future but instead pointed me towards the Lg and Stage solution and said that a new stand not very different from the Horizon stand is on its way. Supposedly it is a fixed stand not moveable but with cable management and the base is not round but has a shape reflecting the beosound Stage.
That sounds somewhat more likely....and with wheels underneath ;-))
Depends what you call an 'update'. The big UK dealer I spoke with said it's just a panel refresh. Same design etc. ie. a very subtle update.
That looks cool with the Stage design!
That's decent. If I ever take the GX off the wall, I'd use that. What's the retail price, anyone know?
Good spot Emil!
It looks very good, and so much more refined than the rehash of old ideas that STB brackets churn out.
Too bad on the lack of an updated Horizon coming down the tracks. Here’s hoping for a beefed up Stage that can be integrated into a wider Beolab based set up, feels like that should be the natural next step.
