I have a ilight lighting system that works off the beo4
when i press cinema my lintronic -238 sends a macro to the lights to dim for watching a film
the trouble i have is that the room behind the light is a normal switch and does not dim
now between the two rooms is an opening but the light switch in the next room is behind the wall (old victorian house)
i was thinking of buying a Rania from sounds hevenly as this can replace the existing light switch.
few questions on that.
Does the Rania just replace a UK switch no external power supply needed?
Can i reprogram the Rania so the i can use light yellow for off etc?
how can i get the IR signal from the lintronic to the Rania without having to put a nasty IR adapter on the front of the switch?
