Help with Beosystem 3 Set Up
Hello
I need some help on setting up a Beosystem 3
The problem I am having is with the sound setup
The configuration is a Beosystem 3 connected to a Samsung TV
Centre Speakers is a pair of 4000’s Fronts 8000’s Rear 6000 and a Beolab 2 Subwoofer
The problem I have is I can’t configure the speakers
 SPEAKER TYPE: When I go to Speaker Type I can hear the sound from each speaker and it will let me store
TV SPEAKER ROLES: When I go to TV Speaker Roles I can hear the sound from each speaker and it will let me select but I can’t store?
SPEAKER DISTANCE: Grayed Out I can’t access
CALIBRATE THE SOUND LEVEL: Grayed Out I can’t access
SOUND AJUSTMENT: I can see and access Volume, Bass, Treble, Subwoffer, Loudness But I can’t see Default Video or Default Audio
SOUND SYSTEM: I can access but can’t make any changes
 I know all the speakers are working as I can hear the sound from them when I try to set the Speaker Type or Speaker Roles
So currently it does not matter what I try to select I am only getting sound out of the Center 4000 speakers and the Subwoofer
I can’t register any other speakers
Can anyone out there point me in the right direction?
Barry
In my experience if you have the latest SW levels without the inbuilt APC Camera on the Mk3 screens only you will experience such problems - you need to go down a couple of software levels, we are experiencing similar problems presently.  If you don't have the latest SW then I am lost too.
Hi
Thanks for your comments sorry for late reply its Chinese New Year here in Taiwan so have had a few other things to do
But am now back to trying to sort out the B&O
How do I check what Software level I have on the Beosystem 3 ?
Where I live is miles away from a B&O Dealer is it possible for me to change the software version myself (If required) or dose the Beosystem 3 need to go back to the dealer
Sorry to ask what are probably common question but I am quite new to all of this
Any more information will be greatly appreciated
Barry
Wish I could help you but I do not know what the problem could be.
Did you get the problem solved?
Make sure you have Default speakers set to Video 5 and Audio 4 in the sound adjustment menu (Top One) IF IT IS A FULL PRO LOGIK SET UP. Then follow each stage of sound adjustment accordingly.
This is the first adjustment you make setting up sound so make sure default speakers are set for what you are using.
Latest software version is 7.05.
You will need the dealer to do this for you.
