Hi All
Hoping someone can steer me in the right direction.
I bought a (working) 1202 a few days ago just to use while I await some components to arrive from Beoparts to get my 4002 over to a local B&O tech for refurbishment. I thought might as well listen to my records while I'm waiting.
I decided to set the speed using the dial on the side and it's gone pear shaped from there. The motor slowed way down, stopped, stuttered (dial not turned full either way) and never came right. I opened it up to see if something simple like a cog or belt or whatever may have slipped, nothing, pieced back together and motor doesn't even spin now. re-opened and found this thin purple wire coming from the power supply that goes to nowhere? it must have come off. Can anyone tell me where this connects? could this be the issue?
thanks in advance, TBH this is only a temp thing until I get my 4002 fully working so I guess if I cant get it going I'll move on but the brief interaction I had with it working it sounded pretty good !
cheers
