HELP WITH A BEOSYSTEM 2 OUTPUT TO NON BV 4 !
Comments are correct the VGA output from the Beosystem 2  is at 50Hz and not many monitors or LCD panels will accept this.
I have a small 22" LCD panel that will work with this and allows you to go to the setup menu's and even then display all the video sources.
Once the unit is turned on, ie pressing a video scource like TV you then press MENU, MENU, 3 and very quicklt followed by 0, 0, GO
You can then press exit and then go back to MENU, MENU, 3  to set up all the other options like sound etc
It can be a little difficult the reason being the BS2 has a VGA output and an RS232 output that talks to the panel and receives signals back from the panal to say that it is on without those signals the BS2 is a bit lost.
Works great. if your anyway near the Worcester area welcome to try sort it out for you.
2000 Euros for a Beosystem 2  I may be interested in selling ?
Regards
Richard
I would advice a good one - but the best solution is a Panasonic Prof. PDP.
Richard,
what is the exact model/type nr. of the lcd screen?
I got a Beosystem 2 MKIII and now I am trying to integrate it....
Using a Pioneer PDP-LX5090H display at the moment NOT integrated.
Thanks!
Ralf
Living Room: Beosystem 4, Beolab 7-2 (Center), Beolab 9 (Fronts), Beolab 8000 (Rears), Screen: Sony KD-85XH9096
Home Cinema: Beosystem 4, Beolab 7-4 (Center), Beolab 9 (Fronts), Beolab 4000 (Rears). Projector: Sony VPL-HW55
Home Office: BeoVision 11-46, 4 x Beolab 3, BeoCenter 9300 (BLC 1611/ML/NL)
Dart Room: BeoPlay V1-40 on floor stand
Guest Room: BeoVision 7-40 MK IV, Beolab 7-2, BeoSound Ouverture
