Thank you very much.
I checked the connectors, and they seem fine to me. I don't have the remote yet, but will get it next week and make the proper checks, that is a very good idea. I asked the previous owner what was his setting, waiting for the answer.
I found in the manual of the beocenter 2 socket this section on the mode setting. I will try that as soon as I get the remote, as I understand that you cannot do the manipulation without the remote for some reason... But shouldn't it be Option 1?
To program Option for your audio system with the Beo4 remote control …
> While holding down the • button, press LIST.
> Let go of both buttons.
> Press LIST repeatedly until OPTION? is shown in the Beo4 display and press GO.
> Press LIST repeatedly until A.OPT is shown in the Beo4 display and then key in the appropriate number (0, 1, 2, 5 or 6).
Option 0: Used when your music system is connected to your video system and no speakers are connected directly to your music system. If you wish to change the Option setting to 0 from any other setting, change it first to 1 before changing it to 0.
Option 1: Used when your music system is set up on its own or connected to a video system, when speakers are connected to your music system
Option 2: Used when your music system is set up in one room and connected to a video system set up in another room.
Option 5: Used when your music system is set up in a link room which also comprises a Bang & Olufsen television.
