Hi everyone, I've got two problems with my Century:
1) Every time I try to play a CD, it starts spinning, then stops and the CD clamper opens.  I've tried cleaning the lens and I've taken off the surround and cleaned the small sensor in the top right of the CD opening, but neither has solved the problem.  Is there anything else I can try, or do I need a new laser unit?
2) The door is working, but mechanism keeps unclipping from it when it opens.  I've taken speaker off, cleaned the bits I can see and gently pressed the clips together to try to get them to hold onto the door better, but it hasn't made much difference - any other suggestions?
Thanks very much for reading - hope you can help!
Neil
