Help needed on a flickering screen
Thanks a lot,
I will have a look with my dealer, and see what he can do. I send you a PM.
Best regards
Eric
Eric
i am now on my 6th BeoVision 7, and on my second latest blu ray 3d version. Last year I had the flickering lines down the tv, it took ages for B&O to inverting ate and sent an engineer from Denmark. Despite lots of head scratching, they were unable to cure it, so replaced the tv with another tv, in fact it was next on the production line. Despite my concerns I accepted it. Low and behold the screen flickers returned, although an earlier lower spec loan set did not produce the problems. This new tv has had the HDMI board replace, the pin board replaced and a new screen.
although the flicker has change position, it is still there. I will be contacting B&O uk tomorrow as they. Are again dragging there feet. This is not the only issue I have come across regarding the screen flickering. I will update as and when I get a solution.
paul
It's the power supply that causes this. It took us and B&O a little over a year to find this out.
Hello mayface,this makes sense because the power supply was the only part in my faulty BV 7-40 Mk6 that was NOT replaced.RegardsRäuberIt's the power supply that causes this. It took us and B&O a little over a year to find this out.
