A bit of a long shot, but is there not a cable cover on the back that is covering where the label is? If you cannot see any of the connections sockets, they are behind a removable cover and the label should be behind there.
Stoobie
Devon,
UK
Stoobie
ok cheers mate, I'll have a look this weekend.
Thanks for your reply. I'll test them out and clean it all up. Cheers! Troy
Cheers CB : )
Thanks for your help Weebyx!
Thanks for your help!! Troy
