Help! HDR1 and Digital TV sound simultaniously ON.
In our system BV7-32" (2004) + BL7.1 + HDR1 and digital reciever we recently encounter a problem.
When we switch from DTV to HDR1 we hear noise in the background. When we stop the HDR1 and turn up the volume the last DTV channel is present.
A week ago we had a power shutdown in our home. So the B&O system wasn't properly turned off. Maybe this has something to do with it.
If so, I like to know how to reset our B&O system to the previous setting.
Hope you can assist me, before I ask my dealer to deal with it.
Sounds like an in- output confusion of the HDR Scart. Maybe your Scart plugs are not properly connected. Disconnect all plugs and reconnect with HDR plug at last. Your BV7 should automatically detect the HDR as V.MEM. Next I would try is to disconnect all devices from the mains for some minutes - you got the PIN code? - and reconnect with the BV7 at last. Hope this helps.
Stefan
