My Beocenter 2 has been in storage for the last 6 months or so - I've plugged it into the mains, and all that I get is the red dot!
You press a key on the control panel and the red dot disappears for 12 seconds before returning!
The unit does not prompt for PIN entry, I have tried entering the PIN despite this, but still nothing.
The unit does not respond to Beo4, Beo5 or Beo6 commands - i thought it might be an 'option' problem, but i cannot even get the unit to change options!
Could it be that the display has gone?
Help me Beoworld, you're my only hope!
