Help! BeoSound 3 users only...
Hi chaps... lost my mobile earlier today which I usually use as my alarm clock. Hence, need to find an alternative. The BeoSound 3 sounds like a good one! Can someone please remind me how to set the alarm on it for 7am tomorrow morning, SD card or Radio I don't mind. The manual is at my Mum's house which is 200 miles away!
Thanks,
Simon.
The user manual is available on the main site.  This extract from it should help you...
Chris.
Make a Wake-up Timer
The Wake-up Timer is a once-only Timer, and must be programmed each
time you wish to use it.
> While the system is in standby, press TIMER. The time for the latest
Wake-up Timer is shown in the display. The digits blink.
> Press  or  to fi nd the time you want the system to start playing.
Press and hold  or  to step quickly to the desired time.
> Press the button of the source you want to use for your Wake-up
Timer; RADIO or A MEM. ‘Pr’ (for a radio program) or ‘A’ (for A MEM)
is shown in the display. If you do not choose a source, the radio is used.
> Press STORE to store the Wake-up Timer. The time for the Wake-up
Timer is briefl y shown in the display.
Got nowhere with that! Nothing happened when I pressed the Timer button. Anyway, so tired so hitting the sack either way, alarm or no alarm. Thanks for your response anyway. I am sure the builders will wake me up when they arrive in the morning.
Cheers,
Simon.
simon,
set an alarm w/ your newly purchased serene... it wakes me up every am!
The Serene is much better.... it can go off every day of the business week without re setting it !
