Help and advice needed for Beogram CDX 2
๐Ÿ˜ฎ Hi everyone, I have recently sent a Beogram CDX 2 by DHL to a fellow ebay member.
The CDX arrived but now the player will not play a complete track, it stops working with a cracking noise coming from the speakers at around the one minute mark give or take a few seconds, has anyone come across this fault and have a quick fix soloution, else a full refund and a battle with DHL is on the cards, Matt
Check if something is blocking the lasers path. It should be able to move freely through the whole path.
Thanks Dillen, yes it may have been jolted during transit and become inhibited๐Ÿ˜
๐Ÿ™ No my colleague has had a look, the mechanism is floating correctly and the laser moves ok he thinks it's electrical?? Has anyone else had similar issues ? Help and advice is always greatly apreciated, Matt
His report is that it plays a cd for give or take one minute and then a crackling sound comes from the speaker ? Matt
It could be the flex cable running to the swinging laser block. I've seen cases where a couple of the
leads in the cable broke as if the cable had a hard bend right there.
Contact was only present with the cable at certain angles.
Will it play the first minute of any track on a CD or just the first minute of any CD ?
Was it secured for transport ?
Your tech guy could check the flex cable connector, where the flex cable goes to the board. And its solders.
๐Ÿ™‚ Cheers Dillen I shall point him to this forum post and maybe he will join us, Matt
๐Ÿ˜ณ As for the transit screws/fitting, no, it was missing on the player, so I thought it unwise to interfere with it, oh what a mistake I have made !!
I did place a small piece of bubblewrap inside to prevent the swing arm from moving though ๐Ÿ˜ณ
Register to access the forums, reference material, and exclusive member benefits โ€” including our monthly prize draw.
