HELP!!!!!!!!!!!!!
Someone help me !!!!!!!!...I get about 50 or so emails a day from Beoworld.....Help
turn off the option to rec'v emails in your settings... it is under the "email" tab...
Well, at least it will keep you up to date with what's happening!😁
Thanks...But where are the settings????
Found it Thanks...............
Hi
1. Go to the following page http://forum.beoworld.org/forums/default.aspx
2. In the top right area entitled "shortcuts" select "forum subscriptions"
3. Deselect any forums you have selected to receive emails from
Let me know if you have any further problems....
V
Click on your own name at the top-right of the page.
Edit: That was quick 😉
You will see at the top right of your screen the words Signed in as Andro Click on your name and a new window will open and about half way down you will find the button to switch off emails - remember to save your changes.
