help!!
Hi
I can't manage to listen tv audio in the audio system speaker
My Beovision 6-26 is connected, through Beolink converter 1611, to Beomaster 6500 (Tv-Aux exit)
what I have to do with Beo4 to make it work?
The istruction are not esay to be understood...
Anyone can help me?
Thanks so much
Gianluca
Do you have them in the same room?
Try to set the options correctly first.
If both systems are in the same room, and speakers connected to BM6500, set audio option to 2:
Press SOUND - 2 - STORE
Set video option to 0:
Press PICTURE - 0 - STORE
Standby LED should flash for confirmation.
If both systems are in diferent rooms set A.OPT to 2 and V.OPT to 2.
If you have a BEo4 consult the manual for option settings.
Now it should be possible to listen to TV sound via your BM6500 by selecting source (TV, DTV, V.AUX....).
Stefan
amagian wrote:
Hi
Anyone can help me?
Thanks so much
Gianluca
Is the TV audio source you're trying to listen to connected over HDMI?  You might have a problem with that particular TV if you're not using the analog connections.
