HELP - Receiver recommendation??
I bought BeoLab 8000 and BeoLab 3 so far. but i couldnt afford to buy BeoSystem 3. too expansive!!!
I am trying to buy a good receiver for my home theater.
Would you please recommend a best receiver between $1,000 and $2,000?
Thank you.
Well you could buy a second hand B&O television with a built in Dolby surround module. Other than that yo may find that $2000 will not buy you a great deal. You have over $12000 worth of speakers so skimping on the source may not be the best idea.
We got a BV3_32 with DSS for a measly $2200... However we don't utilise the DSS yet as we only have 1 pair of Beolabs.
Rather depends where you are. If in the US, then a B&O TV is rather out as there will not be any cheap old ones! I would suggest that this may not be the best forum to get information on other makes.
how about a used beosystem 1?
