HELP - DTS not working on Avant
Thank you very much for your support Stig.
I will go to my dealer a try to get an SW update for the DTS module...
Best regards
Rasmus
Det var så lidt 🙂
Mente nok at have set en dansk post fra dig... 😁
Endnu engang tak for hjælpen, er ved at få en pris på sw update'en.
Rasmus,
Yes, Emmanuel is correct. If the TV software is below 7.3 then you will need to update it as well. The software update requires the replacement of plugin software chip IC3 on PCB6
