HELP - BV7 40 MKII
Your BV7-40 has a DVI input, you can get HDMI Socket to DVI plug adaptor that will convert the end of a HDMI lead to DVI for connection to the set.
You should still connect the Scart for analogue sound, and for the best results you should also obtain a Optical to Coaxial converter to provide connection from the Sky HD Optical digital out put to one of the BV7-40 coaxial digital inputs.
When configuring you simply go in the BV7-40 menu, connections, and for example AV2, set it to DTV (STB), turn on HDTV - DVI, and indicated the audio socket used and the IR output socket for the control.
All should then be fine.
Hi
I'm pretty sure to have a BV7-40 MKII (type 9358 from February 2006) and the only way to display HD source from DVI input is to select AV4 with HDTV option set to NONE.
It necessary to connect an audio cable. Analogic stereo into AV4 RCA sockets or/and digital into one of the digital input (A1 to A4) and "link" it to AV4.
My home configuration is:
An HD source: Freebox HD (Free is a French internet provider: internet + telephone + TV on ADSL line) connected with HDMI to DVI cable into DVI socket.
Input AV4 is set as PC (Beo4 PC input added).
Analogic audio is connected to AV4 sockets.
Numeric audio is connected to A2 (A1 is not free: Philips DVD writer), this input is selected into connection AV4 menu.
That works fine! Except digital audio from Freebox HD... Nothing goes out from speakers.
In fact, both signals (from DVD recorder and Freebox) resemble each other.
From Freebox HD (digital coaxial socket):
link
And from Philips DVD recorder, same source (Freebox analog output internaly converted to digital):
link
Same signal shape but, maybe, not same data...
Any idea?
Take care,
Tux
Oops!
Type 9358 for a BV7-40 means MK-I !
Mk-II start at 9360...
Tux.
