I bought a 28" Avant for my bedroom which had a STB-C installed and Dolby Surround - the Avant in my Living Room did not have a STB-C and was Dolby Prologic - so I took the moved the STB -C to the Avant in the living room and that works fine. However when I installed the Dolby Surround module the TV wouldn't switch on, checked the cables and tried swapping it round but they will only fit one way so that wasn't it. Installed the original Dolby Module and the TV switches on, STB-C works but when I goto Menu, Sound and then speaker I do not get the option to switch the BL4000 speakers on, instead of which I get a menu under speaker which just says Balance rather than allowing me to select speakers etc. etc. Anyone have any ideas on what I've done wrong (I should have stopped at the STB-C!)
