Hello and I have an impedance question for a Beocenter 9000
Hi everyone,
I am the lucky owner of a Beocenter 9000. It was a fixer-upper from eBay that needed the CD door mechanism to be fixed and the glass to be remounted. Now it works like a charm and is a great conversation piece.
I am considering pairing it with some Magnepan MMG-W speakers because they solve some layout concerns and have the added benefit of producing sound for two adjacent rooms. I don't know if they will do all I would like, but I am pretty sure they will make me happy enough. The concern I have is that they have a nominal impedance of only 5 ohms. The Beocenter manual only mentions output at 8 ohms, so I am worried that the amplifier might get a bit hot. I don't plan on driving the volume too high, and I will probably supplement with a sub.
Will the Beocenter be OK? I'd hate to break it!
David
Hi there, and welcome to BeoWorld!
I have very little know-how about the Maggies. Can you provide the speaker wiring details of these? More specifically, the small jumper/connection panel? If they are two-way then the band pass and high pass sections could be wired in series to increase the load... I don't think you will have any trouble in the first place, but this may be something to consider if a problem materializes.
I'm an automotive audio and acoustic engineer. I design loudspeakers and full sound systems for new automobiles. I also dabble with studio, consumer and pro audio projects from time to time.
Thanks for the reply Evan. From what I can tell, these small speakers are not bi-wirable. I think they just have a two wire pigtail coming out of one of the corners so they can be fed through the wall mounting bracket.
